Anyone seen a Proxy Client app for the N80 yet.
My work network uses proxy authentication to access the internet. and there is no setting in the phone for this (or I have completly missed it).
Would be great if some one could code an app if there isnt one out there.
:con? :con?
Maybe this solves your problem: Menu->Tools->Settings->Connection->Access Points. Now you may edit an existing an access point or you may create a new one. Once you are in your acces point settings goto Options->Advanced Settings. There you will be able to configure ip and proxy settings.
Thanks for the info, I have already tried these settings, the problem occurs beacuse the proxy server requires Authentication to allow internet access,
on a normal PC you are prompted to enter
Username
Password
Domain.
However on the phone all I get is an error or Gateway problem.
