Nokia N80 Music Albuns
1 replies · 1,449 views · Started 28 June 2006
Hi
i used to copy my mp3 albuns to the folder "mymusic" and then, create any folders with the name of the artist, and then, inside, i create another folders with diferent albuns, like this for example "mymusic->HIM->Love metal" +"mymusic->HIM->Dark light" etc.
When i update the music library, some of the musics are all mixed up. When i went to "albuns" some music is out and mixed with other, and even some musics are create individualy as an album. I think because of the information is inside of each music. Some of the musics are repeated in diferent albuns, and everymusic has a information of the album that they bellong, like this: a song called "funeral of hearts" has information of the album"love metal", and this song appears in diferent albuns(folders)
Maybe this will make the album organizations mixed up?
I�ve copy the musics using Nokia music transfer program, or a card reader, and copy manually the songs.
What can i do to put the songs correctly inside of each album, without all that mixed up albuns organization in the Nokia music player
Thanks to all
If you go to explorer on you pc and select the tracks you want in the same album, then right click on them and go to properties and in that menu you can give those tracks a unique album name, then transfer them to the blower!!
