how to turn off wifi in n80????
9 replies · 18,214 views · Started 29 June 2006
haijiang wrote:??? anyone know
Hi
this will stop the phone from searching for a LAN connection
tools
settings
connection
Wireless LAN
you can set your options in this menu
Madash
elegantspoon wrote:If I make it say never does that mean its off?
Cheers 😊
yes, you know its off because the icon will disapear from the main menu, its got 4 little squares in the icon, when connected they are blocks, when not connected they are outlines, and when off the icon is removed from the main display.
elegantspoon wrote:Thank you 😃
This is a flippin fantastic forum!
Best one on the net 😊
From Nokia FAQ
Q: How do I switch wireless local area network (WLAN) off on my Nokia device?
A: You cannot switch off wireless local area network (WLAN) on your Nokia device. To reduce battery consumption, you can specify that your Nokia device does not scan for available networks.
To turn off the background scan:
1. Press the Menu key, and select Tools > Settings > Connection > Wireless LAN.
2. Select Scan for networks > Never.
3. To save your changes, select Back.
When Scan for networks is set to Never, your Nokia device still listens to available networks, and you can use available WLAN networks as usual.
so does anyone know what it actually means? setting it to "never scan" but it is actually "still listening" for signals???
i have followed the instructionsd to change the scanning for wlan to "never" and it still continues to "search for available access points: select access point and what appears is wlan.
how can i fix this?
