Some files won't delete!
3 replies · 4,005 views · Started 29 June 2006
Hi, I installed the blackberry connect software on my phone and realized after that it's not compatible with my service provider.
So I uninstalled it and noticed that there's still some traces of the blackberry connect software.
The files are:
- bb_mtm.txt
- bb_mtm_deinstall.txt
- BlackBerryStartup.txt
The bb_mtm_deinstall.txt file contains this text:
DeInstall of BB_MTM started...
Creating Mutex
Mutex Opened
Waiting on Mutex
23:39:07.380375
Done waiting on Mutex
23:39:07.385375
RunL Entered 23:39:07.390375
Opening Message Server session to change settings
RunL Exiting 23:39:07.457375
RunL Entered 23:39:12.470750
Uninstalling MTM Group
Uninstalled
RunL Exiting 23:39:12.564750
RunL Entered 23:39:12.600125
Asking transport server to delete database
Transport database deleted
Successfully changed attributes for the BB database
Successfully deleted the BB database
RunL Exiting 23:39:13.046000
RunL Entered 23:39:13.052000
Checking Default Email Service
Finding BlackBerry services
Deleting entries
RunL Exiting 23:39:13.090000
RunL Entered 23:39:13.417000
Closing Message Server session
RunL Exiting 23:39:13.516000
RunL Entered 23:39:13.525000
RunL Exiting 23:39:13.536000
Destroying DeInstaller
Releasing Mutex
23:39:13.550000
DeInstall of BlackBerry MTM completed
Each time I want to delete them my phone displays this message: The mobile phone rejected the operation!
Oh and by the way, does anyone knows what's the preInstalledAppsCache.dat file is for?
Is it all my phone system stored on this file so when I format my phone the system doesn't erase too?
Is it possible that some of the supporting files are still being used/running? That's usually what happens when you want to uninstall something like an AutoKeypadLock because it starts itself when the phone is booted and sits in the background. Perhaps you need to stop the Process by using Best TaskMan. It would be worth downloading to see what's going on. Can't help with the second bit. Perhaps someone else will.
Tim
If the only traces are three text files, I wouldn't worry about whether they're there or not, they take up almost no space at all and they don't do anything either because they're not application files.
krisse wrote:If the only traces are three text files, I wouldn't worry about whether they're there or not, they take up almost no space at all and they don't do anything either because they're not application files.
I know, but it's just annoying seeing 3 txt files sitting around like this in my phone lol.
