I have just bought the nokia N80. I have researched and found that it already has the new Firmware.
I go to install the Nokia PC Suite on my new computer and it just comes up with the error, "There is no avaliable connection type and therefore connection to the phone cannot be established and then it then closes", i have downloaded the NOKIA PC SUITE CLEANER and this doesn't work?
"Failed to detect avaliable connection types, Please reinstall PC Suite" What are all these errors about, i have removed the version i got on disc and dowloaded it from the web, still no joy.
I also get "connection to Nokia PC Suite failed, Please reinstall Nokia PC Suite. (code Init IMediaControl2"
HELP! How can i get PC Suite running?
orfoster wrote:I have just bought the nokia N80. I have researched and found that it already has the new Firmware.
I go to install the Nokia PC Suite on my new computer and it just comes up with the error, "There is no avaliable connection type and therefore connection to the phone cannot be established and then it then closes", i have downloaded the NOKIA PC SUITE CLEANER and this doesn't work?"Failed to detect avaliable connection types, Please reinstall PC Suite" What are all these errors about, i have removed the version i got on disc and dowloaded it from the web, still no joy.
Did you install the phone drivers ?
when u connect the fone via usb , i should ask what software u are using on the fone , select pc suit , and it should do the rest its self
Can anyone help... I'm trying to play the Window Media Audio Video files on my N80.
I've searched the forum but not found any clear instructions on how to do this..
Many thanks
The N80 does not support Windows Media Video (WMV) files at all, or DRM (Digital Rights Management) protected Windows Media Audio (WMA) files.
N/A wrote:The N80 does not support Windows Media Video (WMV) files at all, or DRM (Digital Rights Management) protected Windows Media Audio (WMA) files.
can i please ask what phone you are using currently? it would greatly assist in me deciding if i should buy the N80 or not. thanks...
