Hello :
Actually i have a qtek 9000 , and i can recive my email. Just put the mailserver domain , pass , user and domain.
If o swap to a n80 , can i stil recive my corporate email ?
Thnks a lot
Luis,
Hello :
Thnks a lot
Luis,
Yes you can. You can try using the Mail for Exchange software on the Nokia Business site or you can use Data Viz RoadSync.
Or configure the Exchange server (and network firewalls) to allow IMAP4 or POP3 access to email.
Rafe wrote:Yes you can. You can try using the Mail for Exchange software on the Nokia Business site or you can use Data Viz RoadSync.
Rafe : Thnks a lot. I cant find Mail for Exchange software on the Nokia Business site.
Btw : ive instaled roadsync i want to do a fresh instalation how do i remove the files ? Is there any hard reset on the n80 ? Soft reset didnt solve.
Thnks in advance
Luis
Yes you can hard rest a phone using the following code:
*#7380#
Try looking here on the Nokia business site:
http://www.businesssoftware.nokia.com/activesync_downloads.php
The code dont work....🙄
But thnks
