im looking for a new leather case for my n80, i prefer a horizontal belt clip, looking for something that fits it nicely, preferably something that covers the phone completely so it'l be safer from falls. Anybody have suggestions for which I should get?
which case do you guys use for the n80
cbcharlie wrote:im looking for a new leather case for my n80, i prefer a horizontal belt clip, looking for something that fits it nicely, preferably something that covers the phone completely so it'l be safer from falls. Anybody have suggestions for which I should get?
Neri Karra - leather horizontal case. :icon14:
If you do a search for cases you will find that many cases have been discussed here, check out this link
http://www.allaboutsymbian.com/forum//forum/thread/46960/&highlight=cases
I use this one from ebay, clear plastic type. It is the best case ever and fully protects my phone. Its from a Uk seller and the cheapest on ebay. I'm well chuffed with it!!
Here's the link:
I've found this one does the job quite nicely.
It's just a bit of a pain to take it out when you want to use the number pad, though.
James761 wrote:I use this one from ebay, clear plastic type. It is the best case ever and fully protects my phone. Its from a Uk seller and the cheapest on ebay. I'm well chuffed with it!!
Here's the link:
I'm not sure about these plastic cases. I found that I got little grits of dust stuck under neath the case which then compressesed against the phone whilst in my pocket, scratching the N80 a little.
I bought the following belt clip case from eBay.
It's smashing but doesnt do much for my image. Its like having a belt on bag that you carry money about with. I think I still stick with it been in my pocket.
i have found that the krusell case for n80 is the best so far, perfect as it dose not lose any reseptions unlike others i have tryed.
you can pick it up from online aution.😎
I got the cheap Hard Plastic snap on case on Ebay for $5 w/ shipping. It's descent for now.
yeah, I got a clear plastic one too.... its good... tho needs cleaning often as you cna see the crap get inside it easier than leather cases! 😮
i bought one of the silicone cases off ebay lasst week, it was ok, fits well and there is a rial on the side so it clicks into place, protects the fone well and is relitively thin, but after much p1ss taking from my mates asking why i have my fone in scuba gear i decided to ditch it, might go for the clear plastic variant as had on for my 6280 and was quite impressed.
i also got the plastic one
'ello.
I'd like to say, that I think leather cases are absolutely ugly.. If you're gunna own a smartphone you should show it off. Putting an ugly, bulky, leather oldman case over it is mutilation.
I hope someone agrees with me.. Maybe its a teenager thing.
Joel
