Photos for incoming call
4 replies · 2,307 views · Started 30 June 2006
Hello All,
Anyone knows :
1) what is the optimum resolution (dimension) for attaching pictures in contacts? I'm looking just right e.g. balance between size and aspect ration.
2) Where this is exactly stored in nokia phones (contacts database or individual files)?
3) How to set to enable displaying photos for incoming calls? I thought this is automatic in other phones, but in E61, it doesn't work.
One more thing, the voice dial confirmation sound soft i.e. not audible. Is there a way to set this? (tried with outdoor profile).
Some members have been having problem with Lastname Firsname issue, that is confirmed issue with some APAC variant (e.g. with Chinese language support).
Hello All,
Anyone knows :
You can add photos to callers by going to the image file (go to Media, then Images, then select the image you want), then:
-Click Options
-Select Add To Contact
-Select the contact or contacts that you want to associate this image with
The image is converted into a thumbnail and stored with the contact, so you can delete the original file and it won't affect the contact image.
