I see my favourite DVDPlayer hasn't been released yet. Never mind.
So Im trying to convert my MPEG2 files (ie, video captures of my holiday movies) 🙄 to a suitable format.
DivX is currently out the question, so it looks like MP4?
So...
PocketDivXEncoder - Great, Fast, Does not support generating MP4's and it's settings are severely limited.
Omniquitti Lathe - Based on the above. Great, not quite as fast, but a lot of settings. But the only MP4 solution is for iPods, where you just cannot break out of the 320x240 resolution.
VirtualDub2 - While capable of producing great files, with the right FourCC Code, seems not to create MP4s, while there is an MP4 plugin! Argh.
ImToo MP4 Video Converter gave me terrible lip sync
Im just trying SUPER, the first download was corrupted! Just noticing though, the progress bar "starts" over. So it's not a good indication of how far it is through the file! So far LipSync is good, but it's not liking H264, even after setting for 1.2. H263 works. I tried coding a 5 minute file. Fine. I tried coding a 30 minute file, I get the error in Quicktime "Error -2041: an invalid sample description was found in the movie." and it won't play in the phone.
MediaCoder seems pretty good. A bit haphazard, but it is still beta. I detest having to save my files as 3GP's though. I can't just use the settings I give to make an MP4 container. But when all else fails, this works.
Im wondering if there's anything else. Any work arounds for VirtualDub? PocketDivX, Lathe, Super? What am I doing wrong? Anything else I can try without buying?
Any other thoughts? I've had a look at the S60 Multimedia Blog (thanks to links on this forum), but was unable to do H264 using Super.
Cheers
Simon
