Will the wireless LAN work at home with my Belkin Router?
4 replies · 3,458 views · Started 30 June 2006
Looking over the internet all i see is this linksys thing, im not to good in this area so i call for help! I have my belkin f5d7633-4, it is password protected i know, and i would like to connect my n80 to this. If there is a step by step guide for a BELKIN that would be great as all the guides i have seen are linksys and different to my gear. Thanks in advance for your kind help.
Hi, well I'm not too clued up in this department either but I use a Belkin wireless router with my N80 with no trouble... Just search for a WLAN find the Belkin one and type in your WPA key. If you give it a name and save it you can quickly connect to it in the future.
If you don't know what it is then I doubt you have it enabled (as it is not enabled by default )- so don't worry about it 😊
hey daveday what did u do exactly to set up ur Lan with ur belkin?
