unable to install .sis themes on 3250
5 replies · 7,396 views · Started 30 June 2006
try going to - tools, then to app manager - this gives you your installed software, then options and remove.
hope this is what your after.
yeah, i am having trouble too. Is only .sis files though, .jars seem to be fine!
when i try and install .sis the way i usually do with a usb and pc nokia suite i get file not supported error message!
i am using a nokia n91 which is supposed to!! other than this i would say the fone is excellent tho!!!!!
