Ring tone per person
3 replies · 2,258 views · Started 30 June 2006
Hi.
I might be a bit thick here. but is there a way of giving each person in my phone book there own ringtone so I can tell who is calling without looking.
Gary
It couldn't be easier. Go to the contact you want to assign a ringtone to and the select 'options' then (and follow this carefully) select 'ringing tone.' This will then allow you to select the required ring tone for that person.
If you have any other problems I suggest you first try 'options' in the area you are having trouble. Scrolling down the list of options will usually produce the required answer.
Hope that helped.
alternatively, you can find the ringtone through the gallery. Pick options then "assign to contact"
Good luck
Hope that helped.
HeHe 😊
