I got to questions.
1. I cant use pc suit for some reason it will not find my n80, so i use data transfere, but where can i put the mp3`s. there is a folder called music in the n80 but when i put music in it i dont find it in the phone.
2.I have tryed innstaling some themes to my phone,. but it dosent work says .sis file not supported. So ir ead some thing about signed sis files, but when i search for themes i select nokia n80 themes in teh drop down menua allways and it still wannt work even if the themes are made for the n80. i have right konfigs on the phone.
Thanks!
Oas wrote:I got to questions.
2.I have tryed innstaling some themes to my phone,. but it dosent work says .sis file not supported. So ir ead some thing about signed sis files, but when i search for themes i select nokia n80 themes in teh drop down menua allways and it still wannt work even if the themes are made for the n80. i have right konfigs on the phone.Thanks!
question 1, everytime you put music onto your N80 it seems you have to update the music library go into music player > options > music library > options > update music library
Question 2, I have no idea
please search the forum in future first if you have problems, most questions have already been discussed in detail here.
