N70 gps receiver advice
3 replies · 1,530 views · Started 01 July 2006
Evening guys and girls. Got myself a Nokia n70, primarily because it was a free upgrade on my O2 contract and I wanted a smart phone on which I could run some kind of Sat nav. I'm sure this question has been asked a million times before but can anyone give me some advice on what sort of blue tooth receiver and software I should go for?..
Cheers:icon14:
Thanks!
Route 66 software seems a lot cheaper than the likes of tom tom...Does it do the job ok?
does the job fine, uses navteq satellites instead of teleatlas, plus buying gps unit and dvd means you can buy whatever size memory card you want instead of ending up with a 256mb card in the full �199 bundle
