3250 Video Format?
15 replies · 7,874 views · Started 03 July 2006
can anyone help me on this i have mp4 files and i can't seem to convert them to play on my 3250 without losing all the quality. Any idea whats the best format to use :con?
squiggy wrote:can anyone help me on this i have mp4 files and i can't seem to convert them to play on my 3250 without losing all the quality. Any idea whats the best format to use :con?
Use .3gp format...
Try doing a google search for nokia multimedia converter 2.0, that will do the trick, use the best quality settings and the quality won't be too bad.
from where u get the mp4 converter for mobile plese tell me
waqarjpb wrote:from where u get the mp4 converter for mobile plese tell me
there is one software that is Virtual Dub Xvid that u can download fom xvid
Why dont you try ulead video converter.support both 3gp and mp4 for video,and mp3,aac.wav etc for audio.i got it free with nokia service pack.check your pc suit cd.i got adorb photo album also.Sending this from my cellphone so more detail later.
i make a mistake. i download xilisoft video converter 3.1 recently. it support 3GP. i try to convert some video files, but i can not change resolution.
In xilisoft, resolution is called "Video Size". You can find this item on the right. feel free to experiment.
evan. in the left panel of xili, there r "add" button and "add directshow file" button. what the different? i try both the 2, the output files r same.
i didnt use (notice) it b4. it must be a new item. i didnt see it in the former version.(i update to 3.1 recently). pay no attention to that if the output files r same.:tongue:
