Ive taken the battery out and put it back in still no joy it refuses to turn on nothing nada on the screen. Battery is fully charged. Any sugestions before i take it back ?
N80 wont turn on
I take it you have tried turning it on while the power supply is connected? Not sure why it would make much of a difference but I had a phone that used to play up every now and then and the only way to wake it up was to plug in the charger and then power it up.
Sorry that's all I have that is constructive.
Are you sure the battery is fully charged?
Are you using the charger than came with the phone or an old charger with the adaptor (if its the old one it may not work).
try removing the memory card from the phone........ removing the battery........ then insert battery and turn phone on without memory card..
Thanks for the tips Im not sure what the problem was but the phone now turns on and off without problems now. I have a feeling i wasnt pressing the button on the top of the phone hards enough :redface:
