I have just got the N80 on '3' on the WT&T700 tariff, not having used a '3' phone before. But my 3G signal at work keeps switching between 3G and GSM with the potential for lost calls each time it switches (often). I also don't like the restricted internet access using the 3G connection (WiFi connection gives me full access to the web) so I am thinking of returning the phone within the 14 days.
My understanding of reading other posts is that on '3' I cannot lock to a GSM signal (I am not keen on using a generic firmware).
My dilema is should I use another network and if so which one and what are the drawbacks of each one (Other than the deals are not as good)
Would I be able to lock to a gsm signal on orange / vodaphone etc
Are there any limitations on which websites I can access on other networks?
Thanks for your time
matabele wrote:I have just got the N80 on '3' on the WT&T700 tariff, not having used a '3' phone before. But my 3G signal at work keeps switching between 3G and GSM with the potential for lost calls each time it switches (often). I also don't like the restricted internet access using the 3G connection (WiFi connection gives me full access to the web) so I am thinking of returning the phone within the 14 days.My understanding of reading other posts is that on '3' I cannot lock to a GSM signal (I am not keen on using a generic firmware).
This 3 issue seems to be quite a big problem, unless 3 release an upgraded firmware version to resolve this issue I would send the phone back and switch to another network, not sure which you should use though.
What firmware have you got, there seems to be a 3 firmware around here somewhere that may be a newer version than what you have.
I have the following
V3.0618.0.2
23-05-06
RM-92
Nokia N80 (45.02)
Is it best to buy direct or should I buy from the internet e2save and OSPS have resonable cash back deals on vodaphone at the minute
matabele wrote:I have the followingV3.0618.0.2
23-05-06
RM-92
Nokia N80 (45.02)
Looks like you have the latest from 3,
Not sure about whats the best deal for you though, I think only you can answer that because you know what you require.
