Hi, there
I have purchased N3230 phone I am having problem when any of my friend sends a mp3 file via BT my phone gives an error 'not enough space , plzz delete some files etc.' I have cheacked my phone memory is free up to 4 mb and memory card is empty.
can any one help me to find out how do i change memory option MMC card (memory card) as default memory for phone ? Or any one has the proper solution ?
YUSUF:con?
Install MsvDriveE, you can find the app in this forum. The limit of the message received will be equal with the free space on the MMC. If you have the 32 MB MMC, I suggest you to change it with a 128 MB MMC at least.
ratza, Thanks for replying me, as u said to Install MsvDriveE, where i will get this software from, if u dont mind helping me with that, yes that is true that im using 32 mb card at this moment, i m planning for 1 gb MMC, but people told me that 1 GB dosen works whith this mode phone, is that true, u tell me what to do, 1GB will work, or i have go for 512mb card for my phone
Plzz do reply to me as i am waiting for ....................
thanks any ways..........
Yusuf
Use your favourite Internet search engine (Google or whatever) to look for "MsvDriveE".
Wirelessly posted (Nokia3100/1.0 (05.91) Profile/MIDP-1.0 Configuration/CLDC-1.0)
Check the memory card
our favourite Internet search engine (Google)Helped me look for "MsvDriveE",
THanks for helping me with this simple problem, i have downloaded and soon i will install it on my phone. And let u know how that worked for me
Thanks once again.............
Yusuf
yusuf310 wrote:ratza, Thanks for replying me, as u said to Install MsvDriveE, where i will get this software from, if u dont mind helping me with that, yes that is true that im using 32 mb card at this moment, i m planning for 1 gb MMC, but people told me that 1 GB dosen works whith this mode phone, is that true, u tell me what to do, 1GB will work, or i have go for 512mb card for my phonePlzz do reply to me as i am waiting for ....................
Yusuf
😊 rs-mmc 1 gb works with n3230.:icon14: , i'm using it now, but better get
updated new version of firmware from nearby nokia service centre.
Whats the latest firmware for 3230?
okay, I tryed installing MsvDriveE in my N3230 phone and it dosen worked,
how that suppose to be not working, can any one help me regarding this problem is there any conflict or it is not compatible with N3230 model plzz let me it is important for me solve this quary,
plzz do reply to me as waiting for ..........
Yusuf:icon13:
yusuf310 wrote:okay, I tryed installing MsvDriveE in my N3230 phone and it dosen worked,
how that suppose to be not working, can any one help me regarding this problem is there any conflict or it is not compatible with N3230 model plzz let me it is important for me solve this quary,plzz do reply to me as waiting for ..........
Yusuf:icon13:
I have a 3230 with MSDriveE, and work well.
After install, you must run MSDriveE, and nothing seems to happens between 5 - 6 seconds, and the phone returns to original screen. After that, the MSDRiveE is running and do is job!
