Problem uninstalling pc suite for re-installing!!
0 replies · 2,289 views · Started 29 November 2002
I have windows xp and had pc suite 7650 working fine with an irda connection but i must have installed another program and now it does not work.
the problem is i can not re-installe the program as it finds an older version in the computer.
I can not un-installe it automatically as during the process there is error of some kind.
So i am stuck!! i can not reinstalle it or uninstalle the pc suite!!
The only reason i need it is for my outlook contacts, for programs i use the computers file transfer utility.
is there another way to transfer contacts from outlook to the 7650?
