There's a program called ListPro for pocket pc that I use last time which is very convenient and useful for me, do any of you guys know such application for symbian S60v3 that could match it?
Here's a description on ListPro. http://www.iliumsoft.com/site/lp/listpro.htm
Anyway, just to share with the forum that the eWallet for poclet pc, also by ilium software, is replaceable with the Handy Safe for my E61.
-riannn
I can't think if a similar list program off the top of my head.
Yes, I see the need for a program like that on the E-series. I had a similar program on my old 9210, but found nothing yet for my E70. I ended up using HandySafe, which provides some of the functionality in terms of lists, but is much more awkward/slow when it comes to creating the lists. It therefore is ok as a read-only tool, but not for lists that you modify often.
riannn wrote:There's a program called ListPro for pocket pc that I use last time which is very convenient and useful for me, do any of you guys know such application for symbian S60v3 that could match it?Here's a description on ListPro. http://www.iliumsoft.com/site/lp/listpro.htm
-riannn
Yeah I just bought handy wallet as a replacement for my very old version of eWallet. As for ListPro? There are Java midlets that do similar things. One is actually called shopping list with a list of predfined items which you can add to. My only problem with this was that you cant add quantities.
cdx47 wrote:Yeah I just bought handy wallet as a replacement for my very old version of eWallet. As for ListPro? There are Java midlets that do similar things. One is actually called shopping list with a list of predfined items which you can add to. My only problem with this was that you cant add quantities.
Yeah I'm aware there's the ShoppingList application for symbian, but the application is just too specific for the purpose of shopping or any other activities that resembles it.
In other hand, ListPro is quite general and can be adjusted accordingly to what kind of list you want.. with or without checkbox, etc...
-riannn
Psiloc List Manager, however, there doesn't seem to be an S60 3rd Edition version yet: http://shop.psiloc.com/en/Application,65555,List+Manager
N/A wrote:Psiloc List Manager, however, there doesn't seem to be an S60 3rd Edition version yet: http://shop.psiloc.com/en/Application,65555,List+Manager
Hey thanks man... two thumbs up for you :icon14: :icon14:
I'll be waiting for the s60v3...
-riannn
