hi, when i try to play swf files, a message appears saying its corrupted?is this is A BUG? DOES ANY 1 TRYED IT BEFORE?
Flash Problem
patora4ever wrote:hi, when i try to play swf files, a message appears saying its corrupted?is this is A BUG? DOES ANY 1 TRYED IT BEFORE?
I read somewhere on this forum about a problem with flash files..did you do a search ?
ya i did, some say that there is that problem, but i have the 17th firmware, can any 1 try it/
patora4ever wrote:ya i did, some say that there is that problem, but i have the 17th firmware, can any 1 try it/
I just did search and there may be a problem because the phone only has flash light on it and its no good for high quality
thnks cash,
i wanna ask onther prob., in the gallery, when u zoom in a pic, thrn zoom out, till 0 % then scroll up or down, the images is distorted. is it normal? its a bug?
patora4ever wrote:thnks cash,
Never tried it before, but just tried it and when I try to scroll the pictures after I zoom in and out then I do get some distortions, so I guess thats a bug
thnx cash,
i hope the 18th firmware solves all this probs, if sooo it will be soo gr8 fone..
Thats not a bug!!! When you see that the image is distorted just wait a few secs. it is like the Sony's Cybershot cameras (the image is blurry at first, but once you wait for like 2 secs it gets clearer).
You just need to wait a little bit for the image to load in the screen
This is the same in pretty much all digital cameras, it's not a bug.
If the full picture in all detail was loaded every time you went up or down it would take ages to switch between photos.
