yet another problem has developed on my current N80.... now the battery status ALWAYS reads ZERO bars... and every few minutes it makes low battery sound and a warning pops up...
this is with Fully charged battery, have cleaned the contacts just incase and its not that....
GRRRRRRRRRRRRRR!!!
And vodafone STILL havent fixed my video calls.....
Edit/Delete Message
Hum.. Radical approach: Backup and full reset?
Memory card - Options - Backup phone memory.
Move images / videos / apps from phone to SD
Switch off, take battery off, put battery back in, press these keys simultaneously "*" + "3" + "Make Call (green)" + "Power Switch"
Has worked for me before in problems I had.
Regds
Star Hash 7370 Hash also does a full factory reset.
Simon
Hi, wat does a full factory reset do? will it revert to older(original) firmware? thanx.
Ares17 wrote:Hi, wat does a full factory reset do? will it revert to older(original) firmware? thanx.
Nope it will keep the current firmware but restore the phone to its original settings.
