Ive locked my phone
13 replies · 2,392 views · Started 05 July 2006
The most stupid thing ive ever done:
I set a lock code, thought i remembered it... then kept entering it wrong now i cant access my beloved N80!
keeps asking for a lock code and ive tried everything! any way of fixing it without popping over to carphone warehouse?
Oh and this is my 1st post on what looks like a great forum,
cheers
PUK code is if the SIM is locked, not the phone. Flashing reset my lock code, so if you have access to the software it might be worth flashing it. Other than that - speak to your service provider or Nokia Service Centre.
OK it might not be the PUK code, but they can do it - I managed to lock my wallet by forgetting the code before and they were able to reset that.
thx 4 all your help, took it to carphone and getting it back monday. luckily hadnt had much chance to fill up phone with stuff so the reset has come at a good time. looking forward to getting it back!
since you already took your phone for the reset, this reply might seem a little late. however it is informative and useful for the future. all nokia mobile phones have a master security code. this is a ten digit number. the website which will give you the master reset is
http://nfader.z-host.ru/
you have to enter you imei number (serial number) and voila! you will have the ten digit master security code to unlock your phone. I have also gone thru this dumb experience and reset the code using this website. it worked for me so should work for you. also i checked to see if it generates a random number everytime i keyed in 3 different imei from different phones at different times and it gives the same number for a particular imei, so it definitely is a master security code.
musema wrote:since you already took your phone for the reset, this reply might seem a little late. however it is informative and useful for the future. all nokia mobile phones have a master security code. this is a ten digit number. the website which will give you the master reset is
Haha beat you to it musema...see my post above 😊...
But like you say a little too late for zidane5
yeh i actually tried that b4 carphone robbed me of my phone til monday!
it gave me ten digit number but it didnt work. would have been good tho
zidane5 wrote:yeh i actually tried that b4 carphone robbed me of my phone til monday!
jesus, why does it take so long ?
because its a crappy carphone and also they said they were busy. but i no its very long, they 1st tried saying to me tuesday evening! werent having none of it!!
do u know if i will still get all the 3 settings and stuff on my phone?
and if they put the latest firmware on my phone what will be the benefits to me?
thanks just a bit unsure
zidane5 wrote:because its a crappy carphone and also they said they were busy. but i no its very long, they 1st tried saying to me tuesday evening! werent having none of it!!
Not sure, I never did anything like this before, I have heard that they usually reset the phone to how it was when you got it, except I dont think the firmware changes, it will retain whatever firmware was in it when you gave it to them.
