Does anyone if there is a minutes software for the N70?
I need something that I can program to take down the minutes or record the mintues used at particular times of the day.
Or I remember my older nokia would show the minutes used during a call, how can I do that with the N70? Can I?
All I can do for now is a summary after i've hung up..but is there a way to display the minutes used while i'm in a call?
Also..for the Screen Saver..the only options I get are the T-Mobile screen saver, Text or date/time .. is there any way to change that to let's say an animated picture or anything else?
Thanks for any help.
there is an option to switch on a counter during call so you can see on your screen:
e.g.
Mr John
0:05.48
about the screensaver, check out the other threads from this forum or do a search for screensaver or themes
The one from www.gosymbian.com is good
I am sorry I cant find any option like that?? can you clarify where to specify ??
Menu / Tools / Settings / Call / Summary After Call=On
And Power Dictaphone is the App you need for Minutes recording.
Unlimited recording and assignable shortcut start/stop from anywhere on the phone (ie press pen 3 times)
Can record in low (AMR) and high (WAV) format.
WAV on the 6630 used to skip and was unusable but it works great on the N70!
