Post your known bugs here;
Im using software version
V 3.0617.06
03-05-2006
RM-92
Nokia N80 (33.01)
And so far the only bug Ive found is that the phone sometimes restarts itself when in the gallery looking at pictures... Anyone else experience this?
Also.. when I was transferring my contacts over from my old 6680 they were not copied over Exactly.. Still done the job but not an exact copy 😞
What about all you lot?
Bugs I have found in My N80 > on O2 >
When sending a text phone freezez until the message is sent, restricting me from using the phone for a minute at most.
When attempting to send a text and a text comes in, the phone sits vibrating away for a good minute, (highly amuzing)
Browser shutdowns when viewing some webpages, not always in same page or even same site.
Im sure there are many many more out there.
winker wrote:Bugs I have found in My N80 > on O2 > When sending a text phone freezez until the message is sent, restricting me from using the phone for a minute at most.
Just on your vibration problem, if you go to profiles and change the ringtone for txt messages you should find one which will only vibrate for a second or two id say..
I have the same problem when sending a txt it can take 30-40 secs before the "Sending Message" screen goes off.. Any one know what can be causing this?
I have the same Gallery problem - it sometimes restarts my phone, also my internet browser closes for no reason & sometimes the phone randomly freezes and i have to remove the battery and turn it back on.
PLUS....
MY BATTERY LASTS ABOUT 24 HOURS WHICH IS REALLY PISSING ME OFF!!!
I have been told to charge for 16hrs with the phone off then drain the bat and repeat 3 times... HOPE IT WORKS! :frown:
burnsyboy wrote:I have the same Gallery problem - it sometimes restarts my phone, also my internet browser closes for no reason & sometimes the phone randomly freezes and i have to remove the battery and turn it back on.PLUS....
Yep, I am trying the reconditioning of the battery, I borrowed a phone from my friend to use, and I am now 12 hours into the first charge ..will let you know how I get on.
Don't know if anybody else has this problem but i have a problem with some podcasts, its stops playing part the way through and i have to restart the player from that point (memory issue?)
Ren�
