Parameter is incorrect
4 replies · 6,172 views · Started 06 July 2006
Does anyone get this error message when copying songs to the 3250 using Data Transfer mode?
Anyone have a solution?
Handiest way I found of transfering songs was just to drop them directly on to the memory card, just go to memory card then sounds and then digital it picks them up perfect
Only thing i could think of then is when connecting the phone 3 options pop up on the phone and i select pc suite mode, maybe this might help?
i get that problem aswell at first i thought it was the cable but it couldnt be because the pc suite works fine. it fransfers some files without "parameter is incorrect" problem but with other files it says it. i am still able to copy things off the phone. also i only get the problem with music and photos. maybe it is something to do with the firmware on the phone. if your on contract you can get the firmware upgraded from where you bought the phone from. hope this helps and please post onto this thread to tell me how you get on. hope you fix the problem:icon14: .
