I got a N91 a few days ago and I have got Tom Tom 5 mobile but I cant seem to work out how ot install it!!
I want to just run it off the HDD and not use a sd card. So I have copied the files acorss to the HDD but it wont run the exe on the phone and there are on sis or other install files with it.
Anyone write a qucik idiot guide of what i need to do/
Is your copy of tomtom mobile compatible with symbian v3, if it was for a previous phone it may not be compatible. In which case it will never work on the N91.
RE: http://www.tomtom.com/products/features.php?ID=260&Category=2&Lid=1
the fact that you can get an install which is declared compatible for N80 (also 3rd edition but also has a SD card slot) aggravates me quite a lot - there is no reason they couldnt release it on dvd for the n91 as they have done a dvd release of the software - but in order for me to test compatability for sure i'd have to buy software knowing i have no support from the company at all, then sell it on ebay at significantly less than cost if it didn't work!
