sssllllooowww motion
4 replies · 1,820 views · Started 07 July 2006
i'm having a problem - when my phone rings the ringtone sometimes goes reall slow as though the battery is running out!
I've got the most recent firmware
an ideas on how to fix this bug??
stuart412 wrote:i'm having a problem - when my phone rings the ringtone sometimes goes reall slow as though the battery is running out!
Did you try another ringtone yet ?
ive had a similar problem, on several mp3 tones including default ones...
it starts ringing, after playing about 1 second, it goes to the beginning, and loops 3 times then carries on playing the rest..
Really annoying!
If you have SAY CALLERS NAME on, try turning it off.. might help
This is presumably because it is having a hard time playing the MP3. It may be related to not enough free memory. Does this happen when you have no applications open or only when you have a number of applications open.
I would imagine this is a big.
Of course it may also be your phone way of telling you not to use annoying ringtones.
