Synchronise with iTunes
5 replies · 7,996 views · Started 08 July 2006
Hi, I'm knew with Symbian. I'd like to know if anybody knows any software to synchronize my Sumbian S60 (Nokia E61) with iTunes. It sould be perfect if it can autofill my phone card also...
Best regards.
I think symbian phones only work with AAC format sound files so if your tunes are mp3 then you'll have to convert them with the Nokia software. I had to anyway with my 6630
I wouldn't convert all my iTunes files to AAC format in iTunes just to upload to my phone because you'll probably have to down sample them and loose alot of the audio quality
mamac wrote:Hi, I'm knew with Symbian. I'd like to know if anybody knows any software to synchronize my Sumbian S60 (Nokia E61) with iTunes. It sould be perfect if it can autofill my phone card also...
Best regards.
If you're on a Mac, then yes, you can: http://www.e-series.org/archives/6
If you're on Windows, you'll need to look for something equivalent to the SyncTunes application.
If you are using iTunes on Windows you can use iTunes Agent. iTunes Agent is an application which looks for device it recognises (connected via USB Mass Storage) and enables you to manage the music content of the device via playlists in iTunes. http://ita.sourceforge.net/
If you are using Mac OS X 10.4 you can use Nokia’s Nokia’s Music Manager for Mac which integrates with iTunes (not tested with E61) (http://europe.nokia.com/A4158096). Alternatively you can use SyncTunes (http://www.nesfield.co.uk/synctunes/).
In all instances you will NOT be able to play music bought from the iTunes store (Apple has yet to make the DRM protection to devices other than the iPod).
