M3U Playlists
3 replies · 2,412 views · Started 09 July 2006
Has anyone got M3U playlists working (and not using Nokia Music Manager)? I have transfered the MP3 files and exported tracklist in M3U format, they all show up after updating music library in phone, but when I select a playlist (Track list) to play, the phone displays 'Invalid Tack List' then 'Unable to play selected tracks' ....... The software I'm using is Musicmatch Jukebox BTW and Data transfer mode to show phone as a portable device.
Any help appreciated :top:
😊 TTFN 😊
I haven't looked into this much myself, but I'm pretty sure that M3U playlists (and most other playlist formats) are just text files. So the first thing I'd do is open up a playlist that works and one that doesn't work in a text editor and see what the difference is.
(For a text editor, Notepad should do, but if you find little boxes everywhere then you probably have a Unix style text file, in which case try ConText, which is free and can cope with this.)
:icon14: Cheers for the advice.. I copied the m3u file to desktop and read it in notepad, then read original from phone in note pad. They both refer to the original file location, therefore path is incorrect on phone (as it refers to computer location)
I presumed the path would work much like web addresses (ie from root location of file) must be a bug in musicmatch software, which is strange because the export track list feature I used is also suposed to be able to e-mail track list to a friend (who would not have access to my comp!?!)
I'll just muck around with it later as moving house and missus dropping bab in next fortnight 😮
Cheers gain
😊 TTFN 😊
Maybe you should try creating a playlist on the phone to see what the format should be?
