MsvDriveE Software Problem
5 replies · 8,905 views · Started 10 July 2006
Is MsvdrivE compatible with N3230, Because i Tryed installing, Dosen works in my phone. What to do :con?
is any one there, can help me with this proble:con?
It works on 3230, I have it. You need to install it only once and after that you'll see a MMC icon on inbox instead of the envelope.
yusuf310 wrote:Is MsvdrivE compatible with N3230, Because i Tryed installing, Dosen works in my phone. What to do :con?
😊 maybe u can get other members to give the apps/file again.
then install and activate it, the icon for messaging should change
accordingly, its a great apps for n3230, still fail, contact me.........
got version 1.0.1 of the app which doesn't work for me... any suggestions about which version I should get (and, by any chance, about where I could find it ?)
thanks in advance
ratza wrote:It works on 3230, I have it. You need to install it only once and after that you'll see a MMC icon on inbox instead of the envelope.
I confirm that! I already posted it once in N-Gage forum.
