BTW Anyone seen any FlashLite apps?
4 replies · 2,371 views · Started 10 July 2006
I hate Flash Lite. I have'nt found a single working Flash lite app for my E61 and I went through quite a few of (of the very few half decent) FL apps available at the adobe exchange and none of them worked. Not that it mattered as they were all pretty tame. I had to load my phone with J2ME apps which for the most part work but they are a bit slow to load and can be memory hungry. I want REAL flash. Not this wanna be.
Rafe wrote:When you say they don't work what do you mean? I have some working fine on the E61.
I download them and they dont install! Have you got a list of working FL apps.
You need to copy the .swf files to the Flash folder, you can not install them like sis files.
Is there anywhere other than the "very poor" Adobe exchange where I can find some FL apps?
