E61- Very important info
3 replies · 2,780 views · Started 10 July 2006
When you store numbers into the E61, MAKE SURE you store them into 'tel (business)' or 'tel(home)'.
DO NOT store them into the default 'telephone!'
WHY?
Because they do not SYNC with Outlook and you loose the numbers. So always REMEMBER to choose the TYPE of number and NOT USE the default 'telephone' setting.
Cheers
PS: Also peeved about not being able to open jpeg attachments when using Blackberry Connect on the E61.
What about if I have more than one detail for 'tel (home)'? would all of them be sync to outlook?
*I'm lazy to try it out my self :tongue:
-riannn
