I've lost fonts! When I try to change the font in Word prosessor there's only "Mono". Spredsheet found all fonts. What should I do?
9210 word prosessor lost fonts
You should reinstall the fonts (it's on Nokia 9210i install CD-ROM).
NautilusNemo wrote:You should reinstall the fonts (it's on Nokia 9210i install CD-ROM).
Done, but still there's only "Mono" :con?
Maybe it's a problem related to the kind of document. It's a .DOC or a .TXT?
No, same with all documents (epoc or doc).
Nokia advice to reinstall the operating system, I'll try that :frown:
Poor man.you are unlucky.I hope after you reinstall the OS,the problem can clean.Good luck.
I had a really good read on this, very detail, and very useful information.
Thanks.
