How Do I Format My N70
17 replies · 51,457 views · Started 10 July 2006
Hi Helpers,
I own a Nokia N70. I installed something and now my phone is unbootable. My phone is still capable of being charged.
My phone just seems to freeze on boot up, with it just showing a white background with NOKIA written on it.
I have tried removing both the SIM card and the Memory card and still no luck.
[B]How can I format my phone?[/B]
Warning this will erase everything on your phone. Make sure that you back up everything to an mmc card if possible
Switch of your phone
Press and hold these 3 keys together-
-green dial key-
-the star key(*)
-the number 3 key(very hard to do)
Press the on off switch to the phone
DO NOT let go of the keys until you see a formatting screen
After a few minutes the format will be complete,your phone will be back to factory settings
DISCLAIMER!!!I cannot be held responsible for anything thing that happens to your phone,use this guide at your discretion!!
-green dial key-
-the star key(*)
Thank you Helpers for your kind assistance
This method worked and phone is once again running
i did sucessfully formating the phone, but now the memory card has been locked, password is needed. I did remember that thats no password entered be4, how can this happen....someone help me plz...!!!😮
Great problem... Only with password. Or try a formaton another software, i. e., with a card reader on Windows.
Use card reader to retrieve the data uuh.... i tried but not sucess cuz computer cannot recognize, it says its not formatted...
is there any way to track down the password?? maybe using software on the phone..... any pro of the pro there???? of God here, how nice....
or is there any defult pasword for it, im using kingston DV RS-MMC 1Gb
This problem has been argued a lot of times on this forum. My conclusion... seems don�t have one solution. But do a little search, on previous threads, and You go find a different answers for that kind of problem.
nj7 wrote:This problem has been argued a lot of times on this forum. My conclusion... seems don�t have one solution. But do a little search, on previous threads, and You go find a different answers for that kind of problem.
ya i know, there are threads which talking about phone lock, my my phone have no problem, only with the memory card, can tell me which thread talk about memory card password problem?? thx...😊
soonski wrote:ya i know, there are threads which talking about phone lock, my my phone have no problem, only with the memory card, can tell me which thread talk about memory card password problem?? thx...😊
Is recent... but is need to do a search! If I find, I post.
soonski wrote:Use card reader to retrieve the data uuh.... i tried but not sucess cuz computer cannot recognize, it says its not formatted...
This ain't good. If you forgot you password and also format your phone then you can kiss it goodbye your MMC because nothing can get it to work again.
i'm not sure but some suppliers of memorycards give lifetime quarantee.
secondly.. i had a problem with my nokia reading my memorycard. I had formatted my card but used the wrong formatting. so use i think fat instead of fat32. Then it managed to read it again. also 1234 is a common pasword and otherwise it will take you only 10000 times to try 😉
Hello,
My N70's menu has disappeared, when I press the menu button nothing happens.
I've my N70 sine 5 months and I don't know how to remove its memory card.
please help me in this
