N-Gage Java Installation Error
3 replies · 3,424 views · Started 10 July 2006
Hello, i've been trying to install this Java (.JAR) application but i keep getting a damn error!
It seems to install fine but after it's installed it apparently tries to delete the temp files but then a message pops up saying 'System Error' followed by a ID number.
At first i tried to place the file on my MMC card and install by opening it with FExplorer and that didn't work, so i tried putting the file on 'C:\nokia\install' and install via the JAVA installer thing as i guess you're supposed to do but that didn't work either, same problem.
The application is only 51kb big and i have over 1mb free on my internal memory and over 200mb free on my MMC and yes, the JAVA application is made for N-Gage.
I've tried to format, i've tried to install both to the MMC and Internal memory and nothing works...
Anyone know what to do? :frown:
I have no idea what you said.. but.. i think you asked if the JAVA application was compatible with N-Gage.. and yeah, it is.
I checked and it is.
What I tried to say, was that. Therefore an application, even being JAVA, nor always is compativel with all the telephones. And attention, that applications JAVA consume much memory when functioning and this can be the problem.
