i found this virus on my mmc card but the strange that the the mobile symantec software virus scan can t detect it !?!?!??!:con?
how i do del it from the card and from the my phone ????
thanx :icon14:
W32.Rontokbro.B@mm virus
purplerain wrote:i found this virus on my mmc card but the strange that the the mobile symantec software virus scan can t detect it !?!?!??!:con?
thanx :icon14:
But that's a Windows virus!!! Regardless, if you've copied stray files onto your memory card or internal disk, you can follow this procedure to get back to normal. In your case, you also need to virus-check your PC thoroughly first, just in case!
Steve
