Storing Contacts on the MiniSD
2 replies · 2,047 views · Started 11 July 2006
Does anyone know if it is possible to store Contacts on the MiniSD memory instead of the internal Phone Memory. I have serval thousand contacts that I would like to have synched between Outlook and the e61 but will only be able to do so if I can synch them to the MiniSD memory.
Thanks.
No, the Contacts app will only allow the contacts in phone memory. There should be enough of memory for at least a few thousand contacts (especially, if you install any additional apps to the memory card and save pictures, music, etc., on the card, too).
I have 1300 contacts, all with addresses and notes, as well as 2500 calender items (also restricted to Main Memory).
I've installed a couple of app as well, and I have no problems (so far!)
It's odd, as when you look at Tools/Memory/Memory Details, is shows:
Free Memory: 35mb
Contacts:0
Calender:0
Images: 8655kb
Is this the default, or will it be possible to use the MiniSD as expanded memory?
