does any1 have a app called Sound Meter? its on all 3250s, it is used to measure the noise level, i was just wondering if i can get it on my N80 ^^
Sound Meter For N80??
On their site check if they are S60 v3 compatible, or they specifically say N80 compatible, otherwise you probably can't get it on your phone. The other option is to just try it and see 😊
