hi, i was wondering if anyone had experience with the two ?
Jabra JX10 BT headset and E61 ?
They pair up, but no sound. Anybody know any workarounds?:con? Thanks!
If phone is paired with jabra, but no sound, turn off phone, then make sure headset is in its adaptor, count to 5, turn on phone, and headset should be reet and work. Hope this helps.
I'm using this combination and it's working fine if it works. BUT. I'm using my third jabra jx10. The first two change there name while pairing to Audio/Video and failed to register. The shop has been so friendly to give me a new jabra jx10 twice but it looks like a strange software mix up of the jabra jx10. It happens after listening to an *.mp3 file and making phonecalls afterwards.
The sound quality isn't constant. Sometimes it's perfect and sometimes there are some annoying crickels and crackels with the sound. It's my first blue tooth headset and I'm not sure about what I can expect.
In combination with my E60 it works, but as written by voop-fellow, I also am now using my 3rd Jabra..
1 x no loading
1 x broken earpiece
1 x no sound anymore
So to say : I will advice buying a Jabra...... nope
