storing files
16 replies · 3,553 views · Started 13 July 2006
hi members how do u store files on the memory card, transfered frm the pc (like when u right click the file and press the option send to bluetooth device the file starts storing straight away on the phone memory )
Use PC Suite and its File manager to copy files directly to the memory card.
Or in the Messaging app settings, change the "Memory in use" from phone memory to the memory card.
yogi1771 wrote:hi members how do u store files on the memory card, transfered frm the pc (like when u right click the file and press the option send to bluetooth device the file starts storing straight away on the phone memory )
To send via bluetooth and store directly on to the memory card you will have to change your settings to store all of your text messages on the memory card. Otherwise use the data transfer usb cable, or put your memory card in to your computer.
To change the text message settings, from the standby display:
menu > messages > options > settings > other > memory in use > memory card
my pc suite ent workin, im havin to use normal file transfer as a removable storage device...sucks really. anyone else had prblems wid it? i try n set up the connection to my fone, click next... and theres an error...
'there is no available connection type and therefore connection to phone cannot be established. The wizard will exit'
need help please, cus if i cant get pc suite to work, then i cant install stuff onto it! 😞
Tonk3h wrote:my pc suite ent workin, im havin to use normal file transfer as a removable storage device...sucks really. anyone else had prblems wid it? i try n set up the connection to my fone, click next... and theres an error...
Have you got the latest pc suite from the nokia website, I think itsversion 6.8, I know there were some issues with the previous version, and some versions that were supplied with the phone
Tonk3h wrote:yer i got the latest version....its as if it doesnt detect my usb ports or sumfin? :S
sometimes I have mine not detecting the phone with usb, and I found that sometimes the usb cable connected to the phone didnt make a clean connection, so I pull it out and push it back in again, I also always have to reboot my computer when I get the device not recognosed error when I try to connect my phone and it doesn't work.
Do you have the usb cable drivers installed also ?
im pretty sure the drivers are all there, i just did the standard install from the website, and also from the CD i was supplied with...no luck... are there any other programs that would work?
if not, im plannin on reformatting my pc soon anyways
meh
GazP wrote:Get a usb Card reader?
these19-in-1 etc card devices cost about �5-10...
and are MUCH faster than ANY other method of copying to your memory card.
I can drag and drop albums on it in a few seconds...
But if i was to use N80's usb cable, in "Disk Drive" mode... it takes ages... the same over PC Suite.
http://froogle.google.co.uk/froogle?q=mini+sd+card+reader&btnG=Search+Froogle
thats not the problem im tryin to solve... i need pc suite to actually INSTALL the applications onto it, cus thats the only way i can do it isnt it?
Tonk3h wrote:thats not the problem im tryin to solve... i need pc suite to actually INSTALL the applications onto it, cus thats the only way i can do it isnt it?
you can install applications from the phone memory, or a memory card
just copy the files to you mem card via a card reader, then install them through the file manager, or applications on your phone, or you can download them directly to your phone
