no gateway reply, any ideas ?
2 replies · 14,784 views · Started 13 July 2006
i just got my n91 yesterday and already im fedup with it :con?
ive entered all of the details in access points of my linksys router, but when i try to connect i get "no gateway reply"
i tried playing around with the settings but to no avail and the manual is no help whatsoever.
the nokia website is pretty poor too.
thanks for any advice, regards carl.
Most likely a settings mismatch. If you post what the settings you used/have, it might be easier to see what's wrong. Without details there's not much else that can be said (my N91 works fine with my WLAN; hidden SSID, 128-bit WEP security).
Do you have Settings Wizard in your phone? It has it in the 3250.
Try running the Wizard, it will configure your access points to your network, if that doesn't work.
Your network operator can help you to configure your settings and to ensure everything is set to go for you at their end too, so it might be worth giving them a call.
