N 70 charger ?
6 replies · 1,285 views · Started 13 July 2006
I have to connect and switch on and off the charger several times before the phone will show the charging bars moving and charging the phone. Anybody any ideas. I wonder if the software is faulty or the charger
762223 wrote:I have to connect and switch on and off the charger several times before the phone will show the charging bars moving and charging the phone. Anybody any ideas. I wonder if the software is faulty or the charger
Sounds like the voltage isn't quite high enough, i.e. it's marginal. Are you sure you're not using a charger from an older Nokia?
Steve
slitchfield wrote:Sounds like the voltage isn't quite high enough, i.e. it's marginal. Are you sure you're not using a charger from an older Nokia?
Steve
Same happens to me, when I use a charger that cames with 3230, on N70. In fact is an old model...
Is it possible to tell if the charger is old and if I get a new one will it be the old model ?
See in Nokia site the charger compatible with N70. When they are not in compatible list, may work, but could happen a thing like you describes.
762223 wrote:Is it possible to tell if the charger is old and if I get a new one will it be the old model ?
i use a charger that came with a 5110 nokia it is old just need the adapter to make it work make ie big plug to small
works a treat
