Nokia 6630 problem
2 replies · 2,157 views · Started 13 July 2006
Hi all,
I have a problem with my 6630, i've had it for about 7-8 months, it restarted itself sometimes, but not very often. but now not only that it restarts, but it doesn't start anymore. i push the ON button, the light goes on, but most of the times the screen remains blank and stops, or it writes NOKIA and freezes, or the phone starts (rarely), stays on for 3-4 mins and then the screen goes blank and it stops.
anyone has any ideas ? i don't know what to do with it, and i'd be really thankful if anyone could give me a hint 😊
thanks
DarkEye wrote:Hi all,
thanks
I think maybe you have accidentally deleted a vital file in the system of your phone that's why it's not even booting anymore. Here's what you can do, at the screen where your phone freezes, try to type *#7370#. This will reformat your phone, I hope this works with you phone. And when you do this, make sure you have at least 75% of your battery charge co'z if your phone turns off while it is still in the process of reformatting, your phone will be unusable anymore. I recommend you plug it in your charger just to be safe. Inform me when this process works and saved your phone.
batuzai_23 wrote:I think maybe you have accidentally deleted a vital file in the system of your phone that's why it's not even booting anymore. Here's what you can do, at the screen where your phone freezes, try to type *#7370#. This will reformat your phone, I hope this works with you phone. And when you do this, make sure you have at least 75% of your battery charge co'z if your phone turns off while it is still in the process of reformatting, your phone will be unusable anymore. I recommend you plug it in your charger just to be safe. Inform me when this process works and saved your phone.
I already tried this but it doesn't work 😞
I think it's a hardware problem, because sometimes the light isn't such bright but when i press the screen or the keypads it goes brighter, then it goes back, or so ... it's really strange and i searched everywhere for anything like this but didn't found anything
maybe I have to take it to a gsm service or i donno... :con?
anyway thanks for your reply and for the help
