API to subscribe to Incomming Call Events
6 replies · 0 views · Started 13 July 2006
From Symbian Signed Test Criteria:
Test ID
PHN-01
Test Title
Service Interruption
Test Coverage
Sample
Conformance
Required
Full Description
When there is an interruption the application pauses and saves its state.
The interruptions should be handled appropriately with respect to the
context of the application and the interruption priority.
Which API do you use in S60 V2 to get notified of all these events?
Receiving an incoming voice call
Receiving an incoming SMS
Receiving an incoming MMS
Using the application whilst a VoIP call is
already in progress, and creating a new VoIP
call whilst the application is running (if
An alarm notification event
Connecting external power charger
Switching of UI Modes (e.g. Flip,
horizontal/vertical)
Thank You very much!
> Test ID
> PHN-01
> Test Title
> Test Coverage
> Sample
> Conformance
> Required
> Full Description
It may be easier to not listen to all these events and just pause your
app/state when your app goes to background.
AMK
AMK wrote:
> Alfredo Rueda wrote:[color=green]
>> Test ID
>> PHN-01
>> Test Title
>> Test Coverage
>> Sample
>> Conformance
>> Required
>> Full Description
[/color]
AMK:
> AMK
Hello!
My "Application" is a Symbian Server (that always works in background)
The Symbian Server offers Voice User Interaction to Symbian Applications
(just like Window Server offers Graphical User Interaction to Symbian
Applications).
This Symbian Server uses different resources:
1. Network Device (Voice Recognition is done in a remote server)
2. Audio Device (Record user voice requests and Playback responses)
etc.
Nokia 6600 don't allow Voice Call and IP Connection at the same time, so I
must free the APN when Incoming Voice Call arrives. I observed that Nokia
Web Browser (in Nokia 6600):
1. Detects Incoming Voice Call
2 Closes APN
3. Re-connect APN when voice call finishes
How can I achive the same behaviour?
"AMK" <[email protected]> escribi� en el mensaje
news:[email protected]...
>> Test ID
>> PHN-01
>> Test Title
>> Test Coverage
>> Sample
>> Conformance
>> Required
>> Full Description
> AMK[/color]
> Hello!
> Applications).
> etc.
> 2 Closes APN
You do not need to do this yourself, the system shuts down or pauses the
connection when a call or sms comes in and resumes once done. You need
to make sure you do not time out.
I have noticed at time that when there is an active transfer (downlink
or may be uplink) the caller gets a busy tone. If this is the case then
I guess there is nothing you can do detect an incoming call or sms. You
do not need to bother about this use case.
> news:[email protected]...[color=green]
>> Alfredo Rueda wrote:[color=darkred]
>>> Test ID
>>> PHN-01
>>> Test Title
>>> Test Coverage
>>> Sample
>>> Conformance
>>> Required
>>> Full Description
>> AMK[/color]
>[/color]
AMK
Hello AMK!
About:
"I have noticed at time that when there is an active transfer (downlink
do not need to bother about this use case."
I have expirienced the same behaviour when testing with Nokia Web Browser.
When you download a large file, incomming calls are ignored. But
when there is no active transfer, incomming calls are attended correctly
(data connection is suspended temporary). Using TNifProgressBuf, you will
be able to detect the new state.
The problem is that my Server uses two protocols:
1. Signaling Protocol
2. RealTime Media Transmission Protocol
Server sends / receives hearbeats packets each 5 seconds. Incomming Calls
are always ignored! (gprs connection always remains active)
"Top SymbianSigned Failing Tests" document in "SymbianSigned.com" states:
"5. The application doesn't pause when necessary, for example it
continues when there's an incoming call without notifying the user."
I will not pass SymbianSigned! Please help me!
Are you sure there is no API to Detect Incomming Calls?
In fact, I'm not interested in detecting if GPRS Connection has been
suspended. I'm interested in detecting Incomming Call.
In phones that support voice call and 3G connection at the same time, it's
also necessary to detect incomming voice call. My Server must do a list of
tasks to pass SymbianSign:
1. Stop Streamming Audio.
2. Notify Symbian Applications that the Server will be unavailable during
the voice cal.
3. etc.
>> Hello!
>> Applications).
>> etc.
>> I must free the APN when Incoming Voice Call arrives. I observed that
>> Nokia Web Browser (in Nokia 6600):
>> 2 Closes APN
> connection when a call or sms comes in and resumes once done. You need to
> I have noticed at time that when there is an active transfer (downlink or
> may be uplink) the caller gets a busy tone. If this is the case then I
> guess there is nothing you can do detect an incoming call or sms. You do
>> news:[email protected]...[color=darkred]
>>>> Test ID
>>>> PHN-01
>>>> Test Title
>>>> Test Coverage
>>>> Sample
>>>> Conformance
>>>> Required
>>>> Full Description
>>>> state.
>>> AMK
>>[/color]
> AMK[/color]
> Hello AMK!
> About:
Is this a good idea? From what you are saying, the line will almost
always be busy o receive calls.
I think you have misunderstood this test case. When there is a busy
signal there is no incoming call, you cannot fail the test. If this was
the case the browser would fail the test every time a download was in
progress.
But I don't know the repercussion of always having your line busy.
There are APIs to do that, but for them to work you need to receive the
call. I don't think these APIs can help you if the phone is busy. The
busy tone is controlled by the network.
I may be wrong so please do ask around here some more.
> the voice cal.
> 3. etc.
>>> Hello!
>>> Applications).
>>> etc.
>>> 2 Closes APN
>>>>> Test ID
>>>>> PHN-01
>>>>> Test Title
>>>>> Test Coverage
>>>>> Sample
>>>>> Conformance
>>>>> Required
>>>>> Full Description
>>>>> state.
>>>> AMK
>> AMK[/color]
>[/color]
AMK
