rite this is wierd...i first set up my wireless lan, and first time it worked.... now suddenly its decided to NOT work.... dunno why! its on 3, and its got tha latest firmware... obviously the phone CAN connect to wireless lan, becuz it did it the first time..but its decided to stop working now...anyone else having this problem with n80 on 3? anyone help me? :con?
Wlan?
I sometimes get the message "Gateway can not be found" but it usually sorts itself out and eventually I can reconnect.
What message are you getting and what are you trying to connect to?
I'm om O2 connecting to a Wanadoo Livebox.
rite ive managed to get it goin agen...for now, i think it might be three restricting, cuys when u first open the web browser it says that apparently we have to buy it as an add on, but non way am i doin that....
im connection to ma home wireless router btw..
Ok, I got problems now with my wifi, since I did my battery test and had everything turned off, I am now turning things back on as In need them, I have got everything on as far as the wifi is concerened, it sees my home wifi, and I can define it, but when I try to connect it says connection not available..maybe I missed something, I dont know, any suggestions, I am browsing the forum for any previous posts.
Ta
thats the problem i was getting...
i managed to sort it by deleting all the connections, (apart from my default 3 ones) and then makin a fresh one..works fine now! 😃
Tonk3h wrote:thats the problem i was getting...i managed to sort it by deleting all the connections, (apart from my default 3 ones) and then makin a fresh one..works fine now! 😃
Did you make the connection manually, or did your phone do it automatically, before this problem the phone always did this automatically ...
erm, well it finds the wireless to start with automatically, then i defined it and changed the name i fink, then left it! workin fine now..
Tonk3h wrote:erm, well it finds the wireless to start with automatically, then i defined it and changed the name i fink, then left it! workin fine now..
Ok, I will give it a go tommorrow, thanks for help
no problemo
i have a livebox, im unsure wether i have set up my phone/livebox correctly with each other. the livebox shows up in my acess points but when i connect 2 the internet on my phone it connects via the acess point "orange internet"
how do i change the defult connection??
simmatt wrote:i have a livebox, im unsure wether i have set up my phone/livebox correctly with each other. the livebox shows up in my acess points but when i connect 2 the internet on my phone it connects via the acess point "orange internet"how do i change the defult connection??
yes my friend had that problem, f*cking networks, you have to set the phone to always ask
when you try to connect cancell the connection when it tries to connect through orange internet then options > settings > access point > change to always ask,
then you can choose which access point to connect through next time you try 😊
ok, done that andit asks, tehn i put my security thing in but then it says
WPA authoriastion failed
how can i solve this???
Cash wrote:yes my friend had that problem, f*cking networks, you have to set the phone to always askwhen you try to connect cancell the connection when it tries to connect through orange internet then options > settings > access point > change to always ask,
Hi Cash,
I can access my WLAN when I define it but when I set the phone up to "always ask" the access point I've set up isn't shown? It's a real pain having to go in and define the access points for the browser, email and eMSN everytime I want to access my wireless broadband at home. Any ideas?
scatty wrote:Hi Cash,I can access my WLAN when I define it but when I set the phone up to "always ask" the access point I've set up isn't shown? It's a real pain having to go in and define the access points for the browser, email and eMSN everytime I want to access my wireless broadband at home. Any ideas?
do you have latest firmware, I seem to remeber there was an issue with wifi with the old firmware, but that may have been a memory issue.
Also I have found that if the wifi strenght isn't too good, for me below 35 - 40% sometimes the access point doesnt show up when I am searching.
Cash wrote:do you have latest firmware, I seem to remeber there was an issue with wifi with the old firmware, but that may have been a memory issue.Also I have found that if the wifi strenght isn't too good, for me below 35 - 40% sometimes the access point doesnt show up when I am searching.
My firmware is V 3.0614.0.3
My wifi strength is 80%
:con?
scatty wrote:My firmware is V 3.0614.0.3My wifi strength is 80%
:con?
U got an older firmware follow the guide on
well I did this one especially for N80 http://nokia.dx360.net
Hope this helps
cheers
Dx
I need help with this problem too...
My firmware is: V 3.0617.0.6
I go to define access point, change name, exit, then try to access the web and it says "cannot find WLAN etc..." i have a cable/wireless router and the access point says C&W(8) - so these access points are going somewhere???
Can anyone do a step by step guide pretty please (i am new 😃) also is there a "reset factory settings?"...
Thanks!
maybe u have something that its cutting the signal of the wifi acces to ur n80 phone like a 2.4 GHZ home phone. do u have any other computers using wifi???.
