Help with SDK (going insane...)
3 replies · 1,742 views · Started 27 January 2002
I have received my SDK cd and bought C++6. Started to make the first demo program "Helloworld" and I am having nightmares. When I type in "abld makefile vc6", all I get is "bad command or file name". Can anyone help me please before I take up smoking again?
You should read the docs more thoroughly - before calling abld you need to run bldmake bldfiles so that abld.bat is generated. In other words, RTFM User posted image
I did RTFM thanks. It said "bldmake bldfiles" and it did indeed go and make the "make" files in the relevant build folders. The abld.bat file is present as well. I have tried adding as many directories to the path as I can. I even uninstalled everything and reinstalled it all again. I have written in C before so the vc++ 6 is not a problem for me. I even went to college to brush up on it. The docs just dont say what to do when things dont work... Thanks for your reply by the way.
This is what happened..
C\Symbian\6.0\NokiaCPP\Epoc32Ex\CrystalUI\HelloWorld>abld makefile vc6
nmake -nologo -f "\Symbian\6.0\NokiaCPP\EPOC32\BUILD\SYMBIAN\6.0\NOKIACPP\EPOC32EX\CRYSTALUI\HELLOWORLD\VC6.make" MAKEFILE VERBOSE=-s
Bad command or file name
C\Symbian\6.\NokiaCPP\Epoc32Ex\CrystalUI\HelloWorld>
