After trying and debugging I found out that the problem has to do with the Mailtemplate from Lotus Notes V7. A sync with a mail database using mailtemplate V6 works ok. Any ideas what the differences are between the mailtamplates V6 and V7.
See original post below
I'm Using a E61 with PS Suite 6.8.22 on Win XP Prof SP2 and trying to sync my phone with Lotus Notes 7.0
Contacts sync's ok but Calender/Tasks fail. The message I see on the phone after the sync of Contacts goes OK is "closing the connection" PC suite tells me in the report
"PC Sync-has encounterd a problem and has terminated the synchronisation"
I get this all the time regardless the connection type (Cable or Bluetooth) Also tried it on 2 other PC's with the same result.
Any advise?
Frans
