Hi everybody - I've had my 7650 about 10 days now, although I've been vistiting this excellent forum for a lot longer D
The 7650 is - by far - the coolest phone on the market today P
I have noticed though that there is difference in time of upto 50 minutes
in the time of the clock and that of any call stored in the call log. For
instance if a call is made at 8pm and you go back to the call log and check
the time of the call, it shows that the call was made at 7.10pm !?!
I am running software version 3.16, and have never enabled the "Auto time update" option. I have been transfering files via infra-red, but the time on my laptop is correct, so I don't think that has corrupted things...
Any ideas why this is happening and how I can cure it ?
Also, I deleted an O2 bookmark (for the Games Arcade) from my Bookmarks folder, but there was a shortcut to the bookmark in my Favourites folder...now when I select the shortcut in Favourites I get an error message saying the bookmark does not exist - which is correct - but I can't delete the shortcut in Favourites.
Please can somebody help ?
Thanx for your time
this is just what i think... the time a call or text message made or recieved is recieved from the network and not the phones internl clock, though i'm not sure
Well it happend long ago, and the solution was that when you sync with your laptop, it changes the time, but you say the time you got there is correct... hmmm :-?
Well anywayz, about the favorites, you can delete it by using SeleQ, buy it or use the trial.
Hello I had the same problem you can only do it by flashing your phone nothing else will help.
Mustu
Thanks guys, I'll try the trial version of SeleQ to remove my un-favourite Favourite (!) but I don't understand the process of 'flashing' to cure the time difference in the Call Log - what do I do ? Has anyone else successfully cured this problem ?
Thanks again.
Hey. i did not have the problem on my earlier 7650 but this new one that the NSC gave me seems to have this problem. there is a gap of 30 min b/w the clock and the call log
r u using any kind of clock program like world clock or handy clock ??
if so maybe there is a conflict with the Daylight saving option
try to disable it and change the GMT manualy
:angel: :angel: :angel:
Nightfly
i have this error with world clock pro
always shift the time by one hour when i run the world clock
tell me what to do and how to adjust the Daylight saving option
plz
[quote="didos"]Nightfly
plz[/quote]
first u need to go the world map then choose ur city after that select option and edit
in the edit menu u can set the GMT manually then turn off the daylight saving option select "None"
after that press ok cos sometimes i forgot to press it 😃 then choose ur city again ti update it with the new time setting
hope this help
Thanks alot nightfly
i think it work fine now
[quote="Velocity Boy"]
Thanx for your time[/quote]
This is what seems to be happening. It seems to be because of the time difference on the PC and Phone.
I just got my newly flashed phone. I dint not set the current time on my phone. No thirdparty clocks. Time update off. And i dint even sync the clock. Just sent some files over to phone over bluetooth. And my phone clock is synced with pcs:|
I think ( though it's really funny ) mere sending files seem to be messing up the phone clock :-?
And the one hour time difference most of you observed could have bene as pichu pointed out, due to DST settings on the PC
but what about me i have a30 min diff.. no DST or anything.
and i dont think i used to get it before.????
