PC Suite trouble.
3 replies · 1,943 views · Started 15 July 2006
Hello everyone.
This isn't a problem with phone i guess, or a symbian-oriented. But anyways, i didn't know a better place where to ask.
Recently i bought an USB Epox Bluetooth Adapter (DGI01) for my Nokia 6680. It works fine with it's own software: i can send and receive files from pc and backwards. But when i try to connect phone using the latest PC Suite (6.80.22) it says to me this "Cannot use connection type. Check that all needed hardware, software and drivers are avaliable".
Searched over the internet, couldn't find a solution.
Maybe anyone know where to look/ask at least.
I'll be very greatfull to every answer.
Thank you.
Try install a previous Nokia PCSuite version, like 6.7x. Are a lot of problems with last PCSuite.
but where do i get or download that noki pc suite v 6.7? coz everytym im going to the link of that the version i am always see is the version 6.8.. pls help..
1. Uninstall everything that related with Nokia PC Suite. In Add/Remove program at Windows's Control Panel, it should be:[list=a]
[*]Nokia PC Suite.
[*]Nokia Connectivity Cable Driver.
[*]Nokia PC Connectivity Solution.[/list]
2. Reboot PC.
3. Download, install and run Nokia PC Suite Cleaner.
4. Download, install and run CCleaner.
Clean ur windows registry with CCleaner. Run CCleaner around 5 times or until ur registry very-very clean then reboot PC. Run CCleaner again around 3 times.
5. Install PC Suite (latest version).
Note: remember, whenever Nokia PC Suite Cleaner ask u to reboot your PC, do it 😎
